Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Cammed LS1 idle hunts at stoplight
    Aug 2013
    I did tell you that it was a steep learning curve.
    Post some screenshots.
    That spark table has too much advance, that's easy to increase advance to make a little more torque, but at the expense of knocking.
    Feb 2019
    I've seemed to have figured it out. The fuel trims also seem to be in a more reasonable position. I'm not currently seeing any KR, but I will take the advice and work on correcting spark next. Please take a look at my most current log and see what you think.
    calc 4.efi
    Please see my most recent tune file as well. hot start 100% b4343 increase_calcvet_tuning tips_settings.ctz
    Aug 2013
    Quote Originally Posted by detroitmuscle07 View Post
    Setting things up can be a bit hard when you first start out... but you've got it happening now.
    Fueling looks a lot better now. If you're happy with the fueling, then move onto idle tuning. There's a lot to learn with idle tuning, so take your time and do the reading and learning before you attempt to deal with your idle surge.
    I will give some handy hints...
    Make sure your desired airflow and actual airflow match... if you've got drive by cable, then correct the IAC effective area table by shifting the entire table to make the airflows match.
    Don't assume all surging is airflow related... sometimes spark can be contributing to it.
    Log all the airflow pids... it will give you better insight into what's actually happening when you get a surge.
    Joecar is right, you appear to have too much spark advance... but I have personally seen engines which have carried more spark than you would normally expect, so just make sure you always log for KR and don't worry too much about it if you're not getting any knock.
    Feb 2019
    Thanks again gentlemen. I'm pretty satisfied with the current fueling. May do a few more logs and see if I can clean it up some more. I'm looking into the idle tutorial material now.
  1. cammed vz ss idle trouble
    By h41ry in forum Gen III V8 Specific
    Last Post: May 24th, 2016, 01:04 PM
  2. Replies: 1
    Last Post: March 15th, 2011, 08:17 PM
  3. Idle dip w/M6 cammed LS1 F-body
    By DrkPhx in forum Gen III V8 Specific
    Last Post: September 2nd, 2009, 05:49 AM
  4. Optimal Idle Timing for cammed LSx
    By Goldfinger911 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 8th, 2007, 06:56 PM
  5. Tuning cammed LS1's with large injectors?
    By ViolatorTA in forum General (Petrol, Gas, Ethanol)
    Last Post: April 10th, 2007, 12:41 PM
