Thread: E67 2.4L Ecotec - Throttle Position Issues
    Aug 2015
    Default E67 2.4L Ecotec - Throttle Position Issues
    Hi Everyone,
    I am building a 2006 Cobalt SS 2.4L LE5 N/A 5-Speed Manual, to become an oval track racecar. I have removed a lot of the interior wiring harness, and am working through some issues I've recently run into.
    After removing a lot of the interior harness, the VATS prevented the vehicle from starting. Since then, I used the patch to shut off the VATS, and get the car going. However, the car still would not crank when turned to the run position. I wired my own starter push button to power the starter solenoid, and since then the car starts and drives. However! In neutral, the car registers up to 88% throttle position and revs very well. When put in gear, the TPS maxes out at 40%, and therefore the car is completely gutless.
    Would there be anyway to work around this issue? I can upload a data log if that would help. I know not much tuning is done with EFI Live on these cars, hoping you guys can provide some guidance or possible repairs for this issue. Otherwise, the car is working fine. Log_0000.efi
    You have to log GM.ETCTP instead of GM.TP.
    Aug 2015
    Hi joecar,
    Thanks for the reply. So, I have logged Pedal Percentage, and it reads 100%. So the accelerator is definitely seeing the correct percentage.
    Everyone on the Cobalt forum says the vehicle is definitely in Reduced Power Mode, and this therefore reduces the amount of throttle body movement. I guess my question is, can I bypass the Reduced Power? I am quite sure this issue is being caused by removing something in the interior. If I have to go through wiring I can, but it seems a little overwhelming. I went too wild with cutting, and I
    Aug 2015
    Bump, don't want to bug everyone just wondering if anyone has found a way to permanently remove "Reduced Engine Power". Would like to ensure it doesn't come back randomly, especially while racing
    Aug 2015
    Just to close out this thread. A tuner in California named Steve, who operates a company called EFIHARNESS, was able to modify my OS to run the vehicle entirely standalone. Steve was a life saver!
    Glad you got it sorted!
  1. Throttle Position (TP%)?
    By beav in forum Diesel
    Last Post: July 2nd, 2013, 12:32 AM
  2. What PID does the E67 use to log Absolut Throttle Position %?
    By PRAY in forum E37, E38 & E67 PFI ECM's
    Last Post: April 17th, 2012, 11:30 AM
  3. Throttle Position
    By bstuder11 in forum Gen IV V8 Specific
    Last Post: April 8th, 2012, 12:12 AM
  4. Absolute Throttle Position
    By mvnvltn in forum General (Petrol, Gas, Ethanol)
    Last Post: December 29th, 2008, 10:22 PM
  5. Throttle position 256%
    By vatman02 in forum General
    Last Post: September 27th, 2007, 06:08 PM
