Results 1 to 3 of 3
Thread: OLSD need custom OS?
    Jan 2007
    Default OLSD need custom OS?
    Do I need to do a custom OS to run open loop SD mode? I am helping a friend tune a LQ4 with a cam and injectors in a off road jeep and see no reason to try and tune in a MAF and the exhaust is about 2' past the header straight pipe, its not derivable on the street so I want to be able to get him something close quickly and add to the tune as I can get some logs when he is off road, we do have a WBO2.
    Feb 2006
    Not strictly, but if you want to have both high and low spark tables enabled then Yes (which is a good idea).
    Rgds
    Jim
    2000 LS1 M6, No EGR/Air/PS/CATs. TR230 Cam, COS3, OLSD, LC1 Wideband fitted, Procharger P1SC, 2 Bar MAP, Siemans Dekka 60Lb Injectors.
    All wrapped up in a 2000Lb AC Cobra Replica
    +1 what Jim said.
  1. Help with OLSD idle????
    By johnj in forum Gen III V8 Specific
    Last Post: April 3rd, 2016, 05:03 AM
  2. olsd flash no.crank
    By relentless addiction in forum General (Petrol, Gas, Ethanol)
    Last Post: August 28th, 2012, 10:28 AM
  3. Could the E38 OLSD tuned ?
    By wesam in forum E37, E38 & E67 PFI ECM's
    Last Post: March 27th, 2011, 07:32 AM
  4. Switch from OLSD to OLMAF
    By Alex99 in forum Custom Operating Systems
    Last Post: February 9th, 2009, 03:54 AM
  5. Just went from OLSD to CLSD, some questions
    By Kevin Doe in forum General (Petrol, Gas, Ethanol)
    Last Post: July 7th, 2008, 07:53 AM
