Results 1 to 8 of 8
Thread: Unlinking,previous firmware V2.07.104
    Apr 2019
    Default Unlinking,previous firmware V2.07.104
    Received un-linking instructions and my AutoCal device must be using firmware V2.07.104 or later. Can I reinstall previous firmware? Where would I find it?
    You cannot downgrade firmware, as long as your firmware is newer than this version you can un-link it. This functionality never existed prior to this firmware update, so even if you could go to an earlier version (which you cannot) you wouldn't be able to un-link. Current firmware is 2.07.139 in the latest software (Feb public release). Download the V8 software and upgrade your firmware, then you'll be able to un-link.
    Apr 2019
    Firmware was updated before unlinking and I keep getting a error
    Aug 2019
    Truckcancer. were you able to get this resolved? I'm having the same issue.
    Nov 2005
    Quote Originally Posted by Steve.runge View Post
    Most likely a blank space after the final character.
    Sent from my iPad using Tapatalk
    Aug 2019
    I've tried that and it still wont work.
    Nov 2019
    I am having the same problem. Any answer on this?
    Nov 2005
    If you meet the firmware requirement, the most likely issue is you have a space at the end of your code.
    If the code does not function, please speak with your tuner so that they can generate you the right code.
    Cindy
  1. Flashscan V2 restoring previous firmware how?
    By wildlyfe200 in forum General
    Last Post: June 5th, 2017, 10:52 PM
  2. how can i play logs from a previous firmware
    By restless@westnet.com.au in forum Black Box Logging
    Last Post: February 25th, 2015, 05:37 PM
  3. New PCM, A/C won't work and it's 104!
    By puddlestomper in forum Duramax LB7
    Last Post: August 31st, 2013, 04:50 AM
  4. reflash to previous OS
    By goldbergv95 in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: December 20th, 2009, 05:06 AM
  5. Restoring Previous OS ?
    By DrX in forum General (Petrol, Gas, Ethanol)
    Last Post: November 19th, 2005, 05:19 PM
