Results 1 to 8 of 8
Thread: 2015-2016 LML hiss/rumble idle
    Sep 2015
    Default 2015-2016 LML hiss/rumble idle
    MODS feel free to direct me to the correct write-up thread and delete this one if needed. I'm having a hard time finding any info on this.
    I am trying to change the 5th position on DSP5 tuning to make it hiss at idle.
    I thought the tables I needed to change were Engine Operation > Turbo > Position
    -I am editing 600-1200 RPMs and 0-20 MM3s
    Client's truck has a goofy inline device connected to the OBD2 port and I'm not sure if it's disabling my changes I'm making with the tune. Any help is appreciated. TIA guys
    Lifetime Member Road's Avatar
    Feb 2015
    Quote Originally Posted by honduh View Post
    Did you increase max limit too?
    Sep 2015
    I did not. I’ll check there next.
    Thanks! I AM in the correct tables, correct?
    Sep 2015
    Confirmed min and max were already set.
    Dec 2005
    The SOTF File or as you are referring to it as DSP5 is not 5 tunes, its one tune with a limiter value applied based on switch voltage.
    You cannot make only one of the switch positions rumble or hiss and the others do the opposite.
    Its not the way that particular setup works, you can pick one or the other for the tunes.
    www.mscservices.net
    Sep 2015
    Ahhh I completely forgot about this. So I will need to edit values on ALL low, med, and high altitudes? Do you happen to have a snapshot of the specific tables I need to edit just to ensure I’m doing this correctly?
    Thank you!
    Dec 2005
    Thank you!
    The editor has most of what you need to make it rumble or hiss @ idle, with respect to, that IIRC there is 6 or 7 single bit values as well as a "idle vane position" only table and 15 or so "max vane pos" tables that are currently missing in the editor and have to be found in hex, identified and a CAX created to see/edit them in the editor.
    Most of what you need is in the editor, some trucks will hiss @ idle and then switch to rumble when in reverse or in motion.
    Good Luck
    www.mscservices.net
    Sep 2015
    Good Luck
    Hey Tony,
    I shot you an email. I need a bit more assistance if you are able to help. Thanks!
    Bryson
  1. 2016 LML haze at idle...
    By 02CCSB in forum Duramax 2011+ LML / LGH
    Last Post: January 9th, 2018, 04:59 AM
  2. 2016 LML dirty tune ?
    By staytuned in forum Duramax 2011+ LML / LGH
    Last Post: September 1st, 2017, 01:08 AM
  3. 2016 LML injection timing ?'s
    Last Post: August 29th, 2017, 02:43 PM
  4. 2016 LML new ECM and TCM
    By jeffmarsh750 in forum Duramax 2011+ LML / LGH
    Last Post: June 3rd, 2017, 01:11 PM
