Results 1 to 4 of 4
Thread: Delphi MT88 PCM Bench Harness Info Etc
    Mar 2009
    Default Delphi MT88 PCM Bench Harness Info Etc
    I ended up with this pcm (see pics) running a fairly new big block. year model 2017.
    The very limited info I could find about this pcm seems it was also used on some GM crate engines etc.
    I am hoping to make an information thread. As well as a bench harness to read it "hopefully"
    Feel free to add info if you know anything about these pcms.
ID:	22784Click image for larger version.
    I tried this setup with no luck
    J1-19=battery pos
    J1-20=battery pos
    J1-43=can low
    J1-29=can high
    J2-13=switched 12v+
    J2-28=switched 12v+
    J2-73= gnd
    These ECM's are not running any software like what GM Delphi ECM's have, many of them use some form of J1939 comms (like the MEFI ECM's did), sorry but EFILive probably will not even talk to this ECM even if you get the bench harness wired up correctly.
    Mar 2009
    Thanks GMPX, I was thinking since it has similar plugs to a e67 either converting it or using a whatever pcm the gas 6.0's uses in the newer trucks. I was cross referencing wiring vs an L96 pcm pinout and so far a lot of things are similar.
    Mar 2009
    IF you need any info on these controllers, give me a call as we have used these. Steve 909 910 3867
  1. T-87 Bench Harness
    By Chavez91 in forum Allison 5 & 6 Speed
    Last Post: April 17th, 2016, 08:03 PM
  2. PCM Bench Harness Wiring diagrams
    Last Post: April 28th, 2015, 05:51 PM
  3. pcm bench harness
    By 69camaro5speed in forum Tutorials
    Last Post: March 26th, 2006, 12:03 PM
  4. bench harness
    By madprof01 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 21st, 2005, 03:25 AM
