Results 1 to 3 of 3
Thread: High-Octane Spark Table Question
    Jan 2011
    Default High-Octane Spark Table Question
    On an E38 controller (Camaro, 2011 SS), the High-Octane Spark Table (B5101) axis only goes up to 1.36 grams/cylinder air. That converts to 544 grams/sec at the MAF at 6,000 RPM. However, the MAF table (B1099) goes much higher, to 1,200 grams/sec. So, what happens when the air flow is higher than the 1.36 grams/cyl in the spark table? Does the computer just use the timing values in the 1.36 grams/cyl column for any of the higher flowrates?
    Feb 2006
    correct, but you can also edit the g/cyl axis in some of the later calibrations
    Yes, correct.
  1. Gen IV Octane Spark Table question
    By Protec in forum Gen IV V8 Specific
    Last Post: September 9th, 2012, 01:08 AM
  2. % difference between the low and high octane spark tables??
    By smslyguy in forum Gen III V8 Specific
    Last Post: February 22nd, 2012, 05:46 AM
  3. Spark High Octane table
    By SHOGOR in forum Gen III V8 Specific
    Last Post: July 19th, 2008, 02:53 AM
  4. high/low octane spark tables.
    By s10mods in forum Gen III V8 Specific
    Last Post: December 23rd, 2007, 12:44 PM
  5. Replies: 2
    Last Post: August 7th, 2005, 03:04 PM
