Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Trying to AutoVe but car wont run without MAF
  1. #11
    May 2006
    Quote Originally Posted by GMPX
    C6301, Engine Diag, MAP, Parameters.
    What MAP sensor is it running?, if it is still a factory 1bar sensor then make sure that is set to 94.4
    Thanks, I believe its the factory one, its a delco unit. But this one is hooked up through a vacum hose and is hanging just behind the right valve couver. Shouldn't in be plugged directly to the intake? I blew on the little hose and it seems like it has a crack somewhere. I just cant see it, I think I might have to take off the intake to get it fixed up! ugggrh
    2000FRC 408ci 520rwhp - 498rwtq Callies Crank, Eagle Rods, Diamond Pistons, Absolute Speed Heads, 244 248 cam, LG Headers, FAST 90, TPIS 90, ATI UD, 11.6cr, EFILive, LC-1 Wideband, RPM Trans, DTE brace, Spec 3+, Momo, etc...
    Custom N2O direct port setup with stand alone fuel system in the works
    Idle and Revs
  2. #12
    Jan 2004
    Yes, it should be on the very back of it. You might be able to get your hand in there and physically put it back. If you find this happening again, you might want to put some silicone around the sensor to hold it in place.
  3. #13
    Lifetime Member jfpilla's Avatar
    2003 red vert
    Mods:
    LPE 100mm MAF
    RPM Level 6/4L60e trans
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
  4. #14
    May 2006
    Take all the coils off the passenger side. Reach your hand around were it should be right in back of the in take. Try to feel what some other "person" did to the intake they had to block the hole or thread somthing in to it. Hope to god they didn't ruin it. Plop the sensor back in the hole and connect the connector its tight fit with the arm but it can be done with out pulling the intake. Pulling the intake off takes about 10 to 15min if you have done it before.
  5. #15
    May 2006
    Thanks for the replies guys. The MAP sensor is not connected directly to the intake (FAST) its connected to a rubber hose and the hose is what's connected to the back of the manifold!!! I dont know who did that but it sure looks "bubba work"
    Idle and Revs
  6. #16
    Jan 2005
    Ah bubba.
  7. #17
    Quote Originally Posted by Darkness
    Bubba may know what he's doing. The Map sensor has a tendency to hit the cowl on C5's. Mine is "Bubbad" and works fine . There should be an elbow going into the manifold, be sure it's sealed and the rubber grommet in the manifold needs to be in good shape.
    2003 red vert
    Mods:
    LPE 100mm MAF
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
  8. #18
    May 2006
    Quote Originally Posted by jfpilla
    Bubba may know what he's doing. The Map sensor has a tendency to hit the cowl on C5's. Mine is "Bubbad" and works fine . There should be an elbow going into the manifold, be sure it's sealed and the rubber grommet in the manifold need to be in good shape.
    Yeah I think thats where the vacum leak is, at the elbow, I'm just gonna take the manifold off and do it right.
    Idle and Revs
  1. Replies: 32
    Last Post: June 24th, 2010, 06:21 AM
  2. wont shift to 5th under WOT
    By pullincrazy88 in forum Allison 5 & 6 Speed
    Last Post: April 29th, 2009, 09:09 AM
  3. help please- wont idle
    By mtwolff in forum Gen IV V8 Specific
    Last Post: October 4th, 2008, 01:16 AM
  4. Wont idle when set for AutoVE
    By Rosco in forum General (Petrol, Gas, Ethanol)
    Last Post: April 25th, 2007, 10:27 PM
