Results 1 to 2 of 2
Thread: Wideband 5v output between efilive and aim dash
    Feb 2014
    Default Wideband 5v output between efilive and aim dash
    Hey guys,
    Just after some thoughts.. I have wideband controller which will output 0-5v, which I have bough to wire to my AIM dash. Ideally, I would like to tune with this wideband as well, so I need it to wire to the Flashscan v2.
    I know I can just share the 5v output but my question is what to do with the sensor ground wire? I can wire it to the dash 'sensor ground' or the flashscan one but what about teeing them together? Does anyone see and issue with this? I was also thinking to tee the sensor ground off the OBD plug and run it all to the ECU ground. The only other thought would be to switch them between either device when necessary but ideally both working at once would be good.
    Opinions would be appreciated.
    Thanks,
    Gary
    Hi Gary,
    Which wideband do you have...? Post it's user manual pdf.
  1. anyone use EfiLive as dash or gauges?
    By ace68 in forum Tips and tricks
    Last Post: June 4th, 2014, 03:33 AM
  2. How to match wideband output to {B3601}
    By mr.prick in forum Tutorials
    Last Post: September 20th, 2010, 05:46 AM
  3. Any way to dampen the PLX wideband output?
    By lsx523 in forum Gen III V8 Specific
    Last Post: February 1st, 2010, 06:58 AM
  4. lc1 wideband output ?
    By smslyguy in forum Gen III V8 Specific
    Last Post: September 1st, 2009, 01:19 AM
