Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: 4l80e change gear completely opposite to what it should
    Apr 2014
    After testing something more, it turns out that after running about 1.5 miles, the gearbox works just fine.
    Tried to just turn off the ignition and then start the engine right after then it works fine, but after stopping for 5 minutes to fill the tank then it has to run for 1.5 miles before it works right again.
    97 Chevy RCSB 4WD, Internally stock 350 ,stock PCM, 4l60e, Bassani headers catback
    72 Firebird Formula ,engine 70mod 400 Ram air 3 ,0411 Road Runner PCM program Lextech, Lc-2 ,4l80e , axel9"wavetrack 3.91 ,Front rear brakes from gen5. Camaro,
    Apr 2014
    the reason for 4l80e switching quickly up to 4 gears ,was that the connection C2 16 and 19 on the PCM were grounded.
    so that PCM received signal that 4wd low range was enabled and front axle was engaged.
    Quote Originally Posted by Ponrov View Post
    Odd... I don't see how 1.5 miles factors into anything.
    That explains it... at street speeds in 4wd-lo you would be hitting the shift curves very soon, good job on finding it.
    Apr 2014
    I use this program to program the 4l80e this was very nice to use , now it shift very smooth " https://forum.efilive.com/showthread.php?5876-Tool-to-help-tune-A4-shift-points"
    Now it`s time to try to Calc.VET: correcting MAF and calculating VE (in single log) .
    Br Ponrov
  1. 2005 c6 vette how to change gear ratios in file after gear swap
    By AllOutPerformance in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: September 21st, 2016, 08:48 AM
  2. 4l80e upshifting when held in gear
    By barbermi in forum Gen III V8 Specific
    Last Post: February 21st, 2014, 02:53 PM
  3. manual gear selection overide 4l80e
    By 2500ak in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 6th, 2010, 03:48 PM
  4. 4L80E 2nd & 3rd gear only
    By rickwils51 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 1st, 2007, 05:06 AM
  5. 4L80E 4rth Gear problem
    By almusafir in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 14th, 2007, 01:43 AM
