Results 1 to 5 of 5
Thread: Converting 02 Z06 to automatic, questions...
    Jul 2007
    Default Converting 02 Z06 to automatic, questions...
    I am putting in a 4L65E and will be controlling it via a Compushift Sport, but am trying to figure out which params I need to flash in the pcm to make it compatible w/the auto.
    This is what I was given by RPM:
    2 Blue wires will wire into the reverse light switch wiring at the transmission
    2 Purple wires will wire to the lower clutch pedal switch so that the car will only start in park or neutral
    For the upper clutch pedal switch the pink wires you will tie together so that your cruse will still work
    You will need to turn off the codes for the reverse lock out and skip shift solenoids
    Looking for thoughts as I complete this swap...
    07 Silverado DMax Classic
    Let me see if I can obtain the PCM wiring schematics for the 2002 Z06.
    If the PCM wont be controlling the trans, I'd put a a manual calibration in it. I looked and seems the Compushift has some cool features, not sure what it offers over the factory control though?
    Jul 2007
    awesome, I can't seem to find it.
    The main advantage is I don't have to change PCMs or add wiring to the harness. I also like the ease of changing params on the CompuShift, done by IPhone. As usual, new product, I'll have to test it to find out what its about.
    Hmmm, all I can find is schematics for 2002 Y-car with AT... let me see if I can at least find the MT schematics.
  1. Ethanol questions - converting non-flex fuel to ethanol
    By BLK02WS6 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 5th, 2012, 07:15 PM
  2. Two Engine Swap Questions (less tuning than converting, really)
    By Admiral Ballsy in forum General (Petrol, Gas, Ethanol)
    Last Post: March 10th, 2011, 07:38 PM
  3. automatic updates
    By jfpilla in forum General (Petrol, Gas, Ethanol)
    Last Post: January 3rd, 2008, 03:28 PM
  4. 02 Z06 D1SC tune questions....
    By JET LEE in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: April 3rd, 2007, 08:23 AM
  5. SD tune + Automatic
    By Phil99vette in forum General (Petrol, Gas, Ethanol)
    Last Post: August 10th, 2005, 04:35 AM
