Results 1 to 7 of 7
Thread: Firmware down grade V2
    Jan 2011
    Default Firmware down grade V2
    Hello,
    I know it has been asked before, Is there anyway to 'force' a firmware downgrade? I find it hard to believe that it can't be done. And if not possible, on what chip is the firmware stored?
    Matt
    Feb 2005
    It has always been stated that no reversals are allowed or even supported. Did you loose something? What is the reason behind wanting to downgrade?
    2001 Camaro SS
    EFILive Custom OS3
    Jan 2011
    I just bought a used V2 for cheap, my first v2 has unlimited LS1B stream but the USB doesn't work and is not repairable, I have send it out. So the firmware of that one can't be updated anymore. The 'new' one was accidentally updated. For the tunes to work, i need use an older version of 7.5, 299. But that one isn't compatible with the newer firmware. so i would like to downgrade the 'new' one to math my old one
    Nov 2005
    Quote Originally Posted by derkscustomcars View Post
    Old tune file formats can be compatible with new firmware. Open the tune file, press save to update the format and you are good to go.
    Sent from my iPad using Tapatalk
    Jan 2011
    i realize that but accidentally upgraded the v2 i just bought and i would like to use both side by side, as soon as i upgrade my v7.5, the files generated by that won't work with my old V2 with the LS1B stream
    It's not supported and not much else you can do. Cindy provided an option to upgrade your tune files, but once the FW on a V2/AC is updated, there's no going back. All modern software development is "fix-forward", newer firmwares and software versions have both new functionality and defect fixes so there's not a reason to use an old one.
    Jan 2011
    I figured it out, I will run virtual PC on my laptop and install the older version and the new one.
  1. Replies: 10
    Last Post: February 16th, 2020, 08:24 AM
  2. Brake Tap Grade Braking
    By killerbee in forum Duramax LLY
    Last Post: October 7th, 2009, 03:51 PM
  3. Firmware 2.06.10?
    By samh_08 in forum FlashScan V2
    Last Post: May 27th, 2009, 12:02 PM
  4. new firmware help-please!!
    By dynarex in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 14th, 2007, 11:22 AM
