Results 1 to 5 of 5
Thread: replacement E38 Vats
    May 2008
    Default replacement E38 Vats
    i am putting a replacement e38 in a 08 silverado, can efi live get VATS to work without licensing the ecm? its from the same make/model/engine size.
    You have to license any ECM/PCM/TCM to flash it, period. You can easily disable VATS on the E38, it's about 5 mouse clicks, then license the ECM and flash.
    May 2008
    was hoping to not disable VATS and not program ECM as ECM came from running truck same yr with same motor and trans, 5v supply in old ECM is dying.
    will pull both files tonight and see if they are the same os/cal
    not even sure disabling vats will work as key on these trucks hook to BCM and not ECM.
    basically i don't want to use license to flash this and have the truck still not start, if that is a possibility then i would be better to go to dealer and get them to perform the Theft Deterrent relearn/ flash ECM
    Mar 2009
    There is more than one 5v supply in the E38. You can run all the 5v+sensors on one supply if needed. Steve
    May 2008
    ended up licensing it, it had a different tune on it, same os, copied my tune to it and it still wouldn't start, ended up having to disable VATS to get it to crank/start. now runs but has constant security nag on dash.
  1. E38 VATS Non-start
    By LastCall in forum E37, E38 & E67 PFI ECM's
    Last Post: May 15th, 2018, 03:13 PM
  2. E38 ECM VATS question
    By Brads_rs in forum E37, E38 & E67 PFI ECM's
    Last Post: July 21st, 2014, 05:11 AM
  3. E38 VATS will not disable
    By v8vegaman in forum E37, E38 & E67 PFI ECM's
    Last Post: March 16th, 2010, 03:29 PM
  4. 09 E38 VATS Not Working
    By gmh308 in forum E37, E38 & E67 PFI ECM's
    Last Post: March 14th, 2010, 01:35 PM
  5. E38 cant disable VATS
    By minytrker in forum E37, E38 & E67 PFI ECM's
    Last Post: October 30th, 2009, 04:43 PM
