Results 1 to 7 of 7
Thread: new to tuning, i have a fully built ls1(stroked) (cammed) high compression
    Feb 2019
    Default new to tuning, i have a fully built ls1(stroked) (cammed) high compression
    I have deutchwrks 50lb injectors and am trying to build a program for my car. anyone have converted injector values for efi live? thank you
    The injectors should have come with data for 58 psi fuel system.
    Question: is your FPR manifold referenced or unreferenced...?
    All their data is available on their site which is very nice.
    https://www.deatschwerks.com/gm-calibration-data
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    Feb 2019
    Not sure what that means referenced? its a Wilson(FAST) manifold..built in around 2010
    Quote Originally Posted by sbowling1 View Post
    Does the Fuel Pressure Regulator have a vacuum hose going to the manifold (not the throttle body)...?
    From their 50 lb/hr spreadsheet .xls, fit those data into your injector tables.
    Jul 2019
    Were you able to do your tuning successfully?
  1. Cammed LS1 idle hunts at stoplight
    By detroitmuscle07 in forum Gen III V8 Specific
    Last Post: April 23rd, 2019, 02:56 PM
  2. Cammed LS1 idle hunts at stoplight & reverse
    Last Post: April 6th, 2019, 09:54 AM
  3. E38 Cammed Tuning Steps
    By Jester in forum E37, E38 & E67 PFI ECM's
    Last Post: November 28th, 2011, 10:58 AM
  4. Idle dip w/M6 cammed LS1 F-body
    By DrkPhx in forum Gen III V8 Specific
    Last Post: September 2nd, 2009, 05:49 AM
  5. Tuning cammed LS1's with large injectors?
    By ViolatorTA in forum General (Petrol, Gas, Ethanol)
    Last Post: April 10th, 2007, 12:41 PM
