Results 1 to 8 of 8
Thread: Seed key/unlocking
    Mar 2009
    Default Seed key/unlocking
    Does the seed key get altered/changed even if locking isn't selected? I'm trying to get the .bin file out of my 0411 PCM to make some changes and I'm getting a locked message.
    No it doesn't get changed unless locking is specifically selected......then again on the LB7's they just liked to lock themselves on occasion
    I assume the behaviour is the same for both V7 and V8 when trying read it?
    Mar 2009
    I can read it fine with efilive. I'm trying to read it out with another program and cable so I can get my tune file in a .bin format, and make some changes using tunerpro with some tables somebody mapped out that are not in efilive. I verified my other cable is good with a different 0411 ls1b pcm, but my pcm gives a locked error when I try to read it.
    You could always just ask us to convert your .ctz to .bin for you instead
    Member arinkuddy's Avatar
    May 2014
    Literally just did this same thing. Although I had to sniff the bus while uploading because I couldn't read it out. It worked though.
    Mar 2007
    Other option is that if you have the Tunerpro XDF file, you have enough information to make a CAX file to use in EFILive. Then you could make these changes inside EFILive.
    Mar 2009
    One thing I did notice is when efilive reads the PCM, the displayed seed is $FFFF whereas my spare PCM I bought shows up as $2B76. This PCM has only been flashed a handful of times as far as I know from an 01 S10 to a 02 express, and a few cal changes I've made to it.
    Dec 2008
    Ive had this happen before.Try locking it with EFI live with a key that you generate yourself. Then unlock it to reassign it a new OEM seed key combo
  1. Unlocking autocal
    By Blackice in forum AutoCal
    Last Post: November 11th, 2016, 09:27 AM
  2. Seed/Key, what is the purpose?
    By N0DIH in forum Lounge
    Last Post: December 2nd, 2012, 05:21 AM
  3. Unlocking pcm
    By carter01 in forum Gen III V8 Specific
    Last Post: May 23rd, 2011, 12:36 PM
  4. Locked PCM seed: $0FAA HELP!!
    By onegonewild in forum Gen III V8 Specific
    Last Post: September 3rd, 2008, 02:54 AM
  5. Pcm Unlocking
    By JCA in forum Tips and tricks
    Last Post: October 19th, 2006, 03:22 AM
