Page 1 of 7 123 ... LastLast
Results 1 to 10 of 62
Thread: Current Public Release (Updated: June 12, 2019)
    Default Current Public Release (Updated: June 12, 2019)
    IMPORTANT
    This release saves *.ctz and *.coz tune files using an updated format. All new *.ctz and *.coz tune files that are saved using V7.5.28, V8.2.24, and V2.07.140 (or later versions) will no longer be compatible with older software or firmware versions. Attempts to open a new file using old software will result in error $0525 "Tune file is not compatible with firmware" or "Tune file is not compatible with current software version". Any customer that needs to open *.ctz or *.coz files that have been created or saved using this or a later version of the EFILive software, must also use this or a later version.
    Tuners who support remote customers MUST ensure their customers also update to maintain compatibility.
    Note: Existing *.ctz and *.coz files saved using previous versions of the EFILive software can still be opened by this and later versions of the EFILive software.
    Release Notes:
    Version Numbers:
    After installing this beta release you should have the following software, boot block, firmware versions installed:
    • EFILive V7 software: V7.5.28 (Updated June 12, 2019) To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.2.24 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • Boot Block: V2.07.008 (Jul 4, 2018) To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
    • Firmware: V2.07.140 (May 26, 2019) To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
    Download here:
    Download EFILive V7.5 (Updated June 12: 2019 to fix issue #3)
    Download EFILive V8
    Known Issues:
    Issue #1:
    Workaround:
    None.
    Issue #2:
    Workaround:
    Issue #3:
    When opening *.tun files (or reading controllers) using the V7.5 software an "Access Violation" occurs.
    Workaround:
    Re-download and install the V7.5 software from the updated link above.
    If you have already installed the V7.5.28 software prior to the update on June 12, then the "Check for Updates" will not detect this update - you must download the V7.5 software and re-install.
    Note: your old *.tun files can be updated/converted in bulk to *.ctz files using the EFILive V8 software's Bulk Update option. [F8:Tools]->[F6: Bulk Files]->[Update Files].
    Feb 2011
    What is the work around for .tun files? I have some archived files i need access to from time to time and now am unable to open them.
    Quote Originally Posted by Millsy View Post
    *.tun files should still be able to be opened using the latest software. If you have a *.tun file that will not open with the latest software please log a support ticket and provide an example *.tun file so we can try to figure out why it won't open.
    I just did some testing with some really old *.tun files, (10 years old) and some of them will not load correctly in V7.5 - they cause "Access Violation" errors.
    For any such tune file, you should still be able to open them in V8. Then re-save them as *.ctz files from V8. Then you can open the newly saved *.ctz file using V7.5.
    Meanwhile I will investigate to see if it is possible to directly support *.tun files that are that old in the V7.5 software.
    Feb 2011
    Oh wow, ok will do. See below if it helps (any .tun file)
    As you noted, the problem occurs with all *.tun files in V7. Also as has been pointed out by other users, it also fails when reading any controller.
    A fix will be posted asap. Sorry for the inconvenience.
    Feb 2011
    Thanks Paul,
    Much appreciated
    Regards,
    Millsy
    May 2010
    yesterday I updated to this version via auto update
    today I had a problem the the 7.5 scan tool will not connect to the cars it will show Error code: ERR_NOCABLE/31
    No interface cable found
    tried to restart and tried my other FS2 without luck tried to remove FS2 driver then install it back without luck
    then finally downloaded the full 7.5 and 8 files and install them and now every thing working fine
    I hope this could help if some body have the same problem
    EFILive Tuner
    May 2010
    I don't know if this related to this update
    but when I try to read LS1B using V7.5 an access violation error is occurred
    EFILive Tuner
    Yes, it's a known issue, see #3 in first post.
    It is being fixed and an update will be available in the next day or two.
  1. Current Public Release (Updated - Feb 2019)
    Last Post: April 17th, 2019, 06:34 AM
  2. Known issues with June 02, 2015 Public Release
    Last Post: July 8th, 2015, 05:07 PM
  3. Public Release June 03, 2011
    Last Post: July 9th, 2011, 07:59 AM
  4. Public Release Update June 24, 2011
    Last Post: July 9th, 2011, 06:21 AM
  5. Public Release Update June 06, 2011
    Last Post: June 20th, 2011, 07:12 AM
