Thread: Testing a V2 without a vehicle?
    May 2019
    Default Testing a V2 without a vehicle?
    Hello,
    I found a used V2 for sale that I am interested in purchasing. The GM vehicle which it will be used on is all apart so I can't very well test it using that vehicle. Is there a way to test the V2 by plugging it into a computer that has the EFI Live software on it?
    Thank you for any help.
    You can test the USB portion and that the FS V2 powers on, plus licensing, etc. I dont know if there's a way to test the vehicle comm protocols without connecting to an actual vehicle though.
    Do you have access to any GM vehicle...?
    What year/model/vehicle is yiur car (the one that is apart)...?
    May 2019
    Erik, thank you for your help.
    Joe, I don't have access to any GM vehicle. The one that is apart is a 2008 GMC Yukon XL.
    Jan 2010
    Where are you located? Is the V2 near you or in another state?
    As mentioned, You can plug into a computer with EFI live software installed to see the license details and make sure the unit works.
    As far as the actual flashing portion, You would need a bench harness and an ECU to test. If it reads an ECU it will likely Flash an ECU. Other wise it would have to be plugged into a GM vehicle to see if it reads.
    May 2019
    Quote Originally Posted by 1FastBrick View Post
    Thank you for your help.
    I am in Knoxville, TN.
    There have been a few used FlashScan V2s that have come and gone. They have been distant from where I live.
  1. Dynamic vehicle testing
    By Biodiesel66 in forum Duramax 2011+ LML / LGH
    Last Post: September 26th, 2015, 01:39 AM
  2. Testing wireless...
    By joecar in forum Lounge
    Last Post: July 3rd, 2008, 03:17 AM
