Results 1 to 5 of 5
Thread: Block size
    Jul 2003
    Default Block size
    What size block transfers will this puppy support?
    What it takes :lol:
    Jul 2003
    According to SAE you can only support up to 4k... with 4k blocks you can read a full pcm in 2 mins or so...
    Although with the USB maybe the packet size can be "infinite" or ... a full FLOW of data from the PCM to the PC.
    The problem with dumping the entire Flash in one hit (be it a 512K or 1024K PCM) is if there is any errors you would need to go back and re-read the entire thing, at least with smaller block sizes, be it, 512bytes, 1K, 4K or whatever else you want, you can do a checksum on each block read to make sure the rx'd data is valid and continue on, if there was an error, simply go back and re-read that block only.
    The 'extra' time taken to do that isn't worth worrying about.
    I don't believe the SAE defines anything GM does with their reflash process.
    Remember too, most serial ports will run way faster than a PCM in 4x mode can spit out data.
    Jul 2003
    Really interesting... but what are the chances of running into problems?
    matbe do it in 12k chunks...
    I thought that the serial port was at limitation... but I see it isn't...
    Thanks for clarifying!
  1. Big Block Ram Jet and E38 (LS3) ECM
    By S10Wildside in forum Conversions / Aftermarket Parts
    Last Post: September 21st, 2010, 04:13 PM
  2. wrong firmware and boot block
    By t_dubble in forum FlashScan V2 BB Logging
    Last Post: September 28th, 2008, 12:42 PM
  3. LS1 knock sensor with a LS2 block
    By Camaro SS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 13th, 2005, 02:27 AM
  4. LS1 knock sensors in C5 and LS2 block.
    By jfpilla in forum General (Petrol, Gas, Ethanol)
    Last Post: August 12th, 2005, 05:15 AM
