Results 1 to 7 of 7
Thread: Drag and Drop file issues
    Jun 2019
    Default Drag and Drop file issues
    I seem to be unable to drag and drop my ECM and TCM files in to "Tune" folder. Any help would be appreciated.
    Diesel Forum Support Site Admin
    Nov 2005
    What is happening when you try to move them? Do you get an error message?
    Try the instructions documented here https://support.efilive.com/kb_artic...9562-EUAF-6679
    Cindy
    Jun 2019
    Using the EFILive Scan and Tune method I was able to get MY ECM file in to the tune folder. I am getting a $0194 write failure when trying the TCM file. I looked at the properties and out 6.2MB of space I only have .9mb left with the TCM file being 1.60mb. When I look at my Autocal system I see the E92 Progr 1 and a e92 Full. Any thoughts
    Nov 2005
    Quote Originally Posted by tanman View Post
    From the error code list
    You don
    Jun 2019
    Sounds like the autocal system doesn't have enough memory. Just a thought. Could i upload the ECM program file from autocal to my car first, then unplug and delete the ECM file from autocal and then upload the TCM file to my autocal and then the car. So can I upload each file on a stand alone basis to the car?
    Yes, with EFILive you must flash each controller individually. You could also just move the stock ECM tune to your computer and then just have the 2 tuned files (ECM and TCM) on the AutoCal.
    Jun 2019
    Thank you
  1. unable to drag tunes to BBL via EE
    By MikeyC in forum Black Box Logging
    Last Post: October 6th, 2010, 09:15 AM
  2. General Help, Still Startup Issues, Log File
    By Dale in forum General (Petrol, Gas, Ethanol)
    Last Post: November 29th, 2007, 01:01 AM
  3. Drag Racing logs
    By oztracktuning in forum Gen III V8 Specific
    Last Post: November 7th, 2007, 10:45 PM
  4. a question for you drag racers
    By tgeers in forum General (Petrol, Gas, Ethanol)
    Last Post: June 9th, 2006, 01:13 PM
  5. First Drag Race Log
    Last Post: February 13th, 2006, 07:17 PM
