I was wondering if anyone has figured out a way to get the commanded fuel above 160mm3. I want to push it up to around the EFILive limit of 250 but I seem to be hitting some hidden limiter. When logging it stops at 160mm3 exactly.
And yes I realize the commanded fuel is basically arbitrary I am trying to limit the light switch effect when boost comes up.
