Results 1 to 5 of 5
Thread: Cold Start High Rev
    Jun 2019
    Default Cold Start High Rev
    Having a weird issue with cold starts. When the motor is first started, timing is at 2-4* and the idle is at 1600rpm. After 5s, timing will jump up to 14* and the idle increases to 2000rpm. This hangs for a bit then starts to settle down.
    Can someone step me through how spark gets calculated the first 30s on a cold start? The motor is an LS1/A4(0411 with 12212156 OS) with a cam(226/234 113+2) and stall(yank ss3600). Thanks.
    Are you getting any DTC's...?
    Is the MAF working ok...?
    Increase low end of MAF table to say 20 g/s.
    It might be easier to flash in a stock F-car 12212156 A4 tune and start again (tune VE and MAF and idle).
    Jun 2019
    No DTC's, MAF is working properly and the car runs fine. The only issue is on a cold start the motor revs up and then settles back in. From the log, I can see the spark advance jumping up which I believe is causing the issue, but not sure why that is.
    Post tune and log.
    Jun 2019
    Post tune and log.
    I was able to figure it out. It looks like the Desired airflow tables were too high and after doing another RAFPN it corrected the issue.
  1. High milage 2001 Denali cold idle
    By Ritch in forum Gen III V8 Specific
    Last Post: December 13th, 2012, 04:50 AM
  2. High RPM Cold Start P/N
    By Protec in forum E37, E38 & E67 PFI ECM's
    Last Post: August 31st, 2012, 03:36 AM
  3. Cold start perfect, Warm start flares high
    By samh_08 in forum Gen III V8 Specific
    Last Post: May 12th, 2009, 09:36 PM
  4. Cold start great but warm start sucks."Idle
    Last Post: October 26th, 2008, 12:22 AM
  5. Cold Start
    By pomona in forum General (Petrol, Gas, Ethanol)
    Last Post: April 28th, 2005, 07:11 PM
