Quote Originally Posted by eionmored55 View Post
You transfer the PCM with a .hpt tune. Then, at that point, I show up with EFI and download your tune from the PCM and EFI peruses it fine. (I expect, I've won't ever attempt)
How might the PCM acknowledge the two records and I can download any document that is in the PCM?
Or then again is it that a PCM stacked with a .HPT record is encoded by .HPT and assuming I go in with tunercat or EFI or LS1 alter, I can't understand it? Seems like that would screw alot of folks over.
I replaced your link with plain text.
Any reason you pasted that link in your post...?
