Originally Posted by
BACKinBLACK
cool.... I got some good news finally!!!!!!!!!1 thank god
anyways, i finally found a converter so i got to checkout the LC1 situation tonight. The LC1 was not preprogrammed correctly and was way off. I changed to the needed values and that fixed that problem. I did a little auto VE'ing and the thing is working and running a lot better.
My next question is this. I have the personal addition of EFILIVE, all the latest software downloads and everything, so when i get done autoVE'ing but i want to Leave the Car mafless but in closed loop (semi, i believe) Do i follow the last section in the AutoVe tutorial , the "return to closed loop speed density"??
It says "do not perform this section if you are running an EFilive custom operating system, V3 (2/3 bar support) or later"
and then it lists a whole bunch of steps.
I am not tunnin a C.O.S. but i do have V3 i believe, so do i follow this section or not?
I guess that question may seem dumb to you, it does to me too. Ive come up with different conclusions each time i think about it so i will find out from the experts.
Trevor
