Originally Posted by
Stroker-427
Reading the file......
so you think problem is coming from TPS or MAF..... of course there is no MAF in the car, but zeroing the calibration any strange signal can only be read as zero flow. Intersting !!
One question..... why you scaled VE and Injectors by nearly 11% ?
The net result in the mixture is the same...... so you guess some ECU calculation issue, right ?
The rest is clear.
Sorry for asking, but I like to understand instead to flash the file and to cross fingers.....
Thanks again !!
