Results 11 to 20 of 25
Thread: Harrop Hurricane intake troubles
    Jun 2007
    Thanks a lot !!!!!
    Will let you know tomorrow !!!
    Jun 2007
    Ok, I did a quick test but limp mode was still there.... after 2-3 minutes of cruising around.
    I don't have my laptop with me, so no datalog, but i checked errors and I have:
    P0102 (MAF error, should be ok because engine is running withiut MAF)
    P0108 (MAP error, sensor circuit high..... could be the problem ??)
    P0141 (O2 sensor number 2, shouldn't be an issue)
    P0443 (Purge solenoid, the car haven't EVAP system, shouldn't be an issue I guess...)
    P1514 (If I'm not wrong this should cause Limp Mode, right?..... but why I have this error?.... maybe because of no correlation between MAP and TPS ?)
    C1278 (this is coming from ABS and should be consequence of P1514, right ?)
    My question is:
    Why I'm having P1514 ?
    Should be caused by an uncorrect correlation between MAP and MAF..... but my MAF is off..... and tables C6101 and C6102 are maxed out respectively at 4095,9 and 4000
    There are more tables correlated to this kind of problem ?
    Are my consideration wrong is some way ?
    Thanks guys, any help is very appreciated !!
    Aug 2013
    Quote Originally Posted by Stroker-427 View Post
    This is the code that gets my attention. Get a log for me and make sure you're logging TPS, APP, MAP, IAT, ECT, RPM... and whatever else you want to log.
    Jun 2007
    Ok, will do in the next days !!!
    Jun 2007
    Hi guys,
    sorry for being so late, but I had no time to do it before.
    Here a LOG of some cruising around with at the end the limp mode !!
    Log_0073.efi
    The car have a mild cam, 383 LS1 stroker engine and Harrop Hurricane Intake.
    If I can delete this problem I can't tune the car which, I'm desperate !!!
    Thanks for any kind of help !!!!
    Jun 2007
    Forgot to mention that errors are the same even with new TPS and new MAP.
    Of course P0102 means that MAF is disabled, can P1514 be consequence of P0108 ??
    Really confused......
    May 2010
    I will have a look when I get to my laptop
    can't view the file from this PC
    what injectors do you have ?
    EFILive Tuner
    Jun 2007
    Stock injectors, engine isn't already tuned....... I can't do it if I can solve the problem.
    By the way the car is running smooth when criusing.
    Nobody have found the way to completely delete this annoing limp mode ? I guess many people would be very happy !
  9. #19
    Aug 2013
    I'm desperate !!!
    It takes you 2 months to post a log, but you're desperate?
    I'll try to get to your log in the next day or two.
  10. #20
    Jun 2007
    Hahahaha.....
    yes..... I'm so desperate..... I'm too desperate even to open the laptop !!
  1. Harrop Hurricane MAF vs Speed Density
    By RD in SD in forum E37, E38 & E67 PFI ECM's
    Last Post: April 27th, 2013, 04:45 AM
  2. Harrop Hurricane 8 Throttle intake with E40
    By rally1 in forum Gen IV V8 Specific
    Last Post: April 26th, 2012, 07:16 AM
  3. L5 harrop supercharger goes lean???
    By miguelc in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: August 11th, 2011, 02:26 PM
  4. Having troubles....
    By dmaxlover in forum FlashScan V1
    Last Post: December 25th, 2008, 06:52 PM
  5. Hurricane Katrina
    By Blacky in forum Purchase and Shipping
    Last Post: September 8th, 2005, 12:49 PM
