Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: Harrop Hurricane intake troubles
  1. #21
    May 2010
    Try this file and report back please
    EFILive Tuner
  2. #22
    Jun 2007
    Thanks a lot !!!
  3. #23
    Jun 2007
    Reading the file......
    so you think problem is coming from TPS or MAF..... of course there is no MAF in the car, but zeroing the calibration any strange signal can only be read as zero flow. Intersting !!
    One question..... why you scaled VE and Injectors by nearly 11% ?
    The net result in the mixture is the same...... so you guess some ECU calculation issue, right ?
    The rest is clear.
    Sorry for asking, but I like to understand instead to flash the file and to cross fingers.....
    Thanks again !!
  4. #24
    May 2010
    Quote Originally Posted by Stroker-427 View Post
    The rest is clear.
    Thanks again !!
    while the car is SD tuned so no problem if you zeroed the MAF and it will make sure it will not affect any thing if any of the sanity checks fails
    scaled the VE and injectors because there is a limit in the LS1B ECM which will cause the P1514 but you will not reach it with stock injectors and NA setup this was just to make sure
    any updates ?
    EFILive Tuner
  5. #25
    Jun 2007
    I see....
    sadly i won't be able to test the car before than nex saturday !!
    I will let you know as soon as possible.
  1. Harrop Hurricane MAF vs Speed Density
    By RD in SD in forum E37, E38 & E67 PFI ECM's
    Last Post: April 27th, 2013, 04:45 AM
  2. Harrop Hurricane 8 Throttle intake with E40
    By rally1 in forum Gen IV V8 Specific
    Last Post: April 26th, 2012, 07:16 AM
  3. L5 harrop supercharger goes lean???
    By miguelc in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: August 11th, 2011, 02:26 PM
  4. Having troubles....
    By dmaxlover in forum FlashScan V1
    Last Post: December 25th, 2008, 06:52 PM
  5. Hurricane Katrina
    By Blacky in forum Purchase and Shipping
    Last Post: September 8th, 2005, 12:49 PM
