Results 1 to 4 of 4
Thread: 4L80E swap always in 1st
    Dec 2005
    Default 4L80E swap always in 1st
    Hey Guys
    The ECU on my 80e swap is always showing 1st gear. Is this normal. I’ll post a log and tun tomorrow. I was stationary and slowly working the car through th gears manually but the ECU shows 1st gear all the time except when i shifted it into second.
    Shouldn’t it show park in park and then through the gears as you move the shifter even if the car isn’t moving?
    Glenn
    Mine does that. It's not a problem.
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    Which pid are you looking at (that shows 1st gear)...?
    GM.PRNDL shows P, R, N, D4, D3, D2, D1
    GM.GEAR shows 1, 2, 3, 4
    Dec 2005
    Thanks guys. Im looking at GEAR. PRNDL is not supported. Ill see if I can figure out how to get it supported so I can check it.
    Is there a wiring diagram anywhere on the site that you guys know of so I can check how I wired my trans to my ECU?
    Glenn
  1. How to stop upshift from 1st to 2nd while in 1st gear 2003 silverado 4L60
    By mvvette97 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 19th, 2016, 05:08 AM
  2. Upshift to 2nd gear when in maual 1st-4L80E
    By mysunnshine in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 17th, 2015, 03:12 PM
  3. Need blackbox 4L80E tune for my 4L80E segment swap
    By Supercharged111 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 10th, 2013, 09:57 AM
  4. 4L80E WOT shifting problem. 1st-2nd bounce rev limiter!
    By TransAm-Z in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 20th, 2013, 09:41 AM
  5. Why does 1st gear slam into 2nd? 4L80E translplant
    By 1SlowHoe in forum Gen III V8 Specific
    Last Post: May 22nd, 2010, 08:47 AM
