Results 1 to 5 of 5
Thread: Air Flow Rate limit
    Lifetime Member izaks's Avatar
    Aug 2003
    Default Air Flow Rate limit
    PID: Air flow rate from Mass Air Flow sensor (Grams/s) maxes out at 655.35 . I have increased the value of UNM-16-11 (gps), but it made no difference to the logged maximum of 655.35
    6.8L supercharged high boost running E38 at 10,100+ hz
    Is this a hard coded limit or is there a way to increase the limit
    2011 VE SSV 419 + CAM + Whipple 2.9FF SC + PPV front struts + Bilstein rear shocks + 6L90E with single piece carbon fiber prop
    I can't think of that PID name off the top of my head but '655.35' certainly calculates out (with scaling) to the maximum limit for an unsigned 16bit value (65535).
    It will have a scaler of 0.01 so that is where the 655.35 comes from, unfortunately that is all controlled in the ECM code.
    Aug 2003
    Sorry, SAE.MAF
    Aug 2003
    I logged GM.AIRPERSEC, and it logs past the 655.35 limit
    Glad you found an alternative, the SAE limit is just the limitation of that PID.
    See here:
    https://en.wikipedia.org/wiki/OBD-II_PIDs
  1. Throttle Open Rate Limit B2804
    By a78turbo in forum E78, E83, E84 PFI ECM's
    Last Post: September 4th, 2014, 03:43 AM
  2. Throttle Open Rate Limit B2804
    By a78turbo in forum E39, E80, E82 & E92 SIDI ECM's
  3. Airflow rate from mass air flow sensor (GM.MAF)
    By phils01z in forum Gen III V8 Specific
    Last Post: October 4th, 2010, 12:35 PM
  4. Injector flow rate
    By billiardcue in forum General (Petrol, Gas, Ethanol)
    Last Post: March 13th, 2007, 04:33 PM
  5. Calculated Air Flow rate
    By Dirk Diggler in forum General
    Last Post: June 9th, 2005, 03:31 PM
