Results 1 to 4 of 4
Thread: Reading camshaft retard on 1997 black box
    Jan 2013
    Default Reading camshaft retard on 1997 black box
    Is there a way to read the camshaft retard on a 1997 vortec? i had to replace the distributor and need to set the timing.
    Its just a stupid work truck and the guy i called locally wants $90 to do it. It seems like my $900 GM tuner should be able to?
    i can read/clear codes from the V2 but i cant get the scanner software on my laptop to do anything, it doesnt recognize the pcm.
    Connect to it as a 98-00 Black box or try the LS1 PCMs. Should be a generic PID so just need to get the V2 connected.
    Jan 2013
    I tried a bunch of different pcm selections and it always said pcm not detected.
    Im just going to 0411 swap it i guess. I have a couple licensed pcms sitting around so its going to be free vs paying someone to do it.
    Mar 2009
    You might could try the 98 ls1a pcm to see if that works. I use my tech 2, so I don't know about efilive doing it. I do know externally 96/97 looks the same as 98-00, but internally they're completely different animals. And make sure and use the cax file for the p/n switch type do you don't have to run the 4 wires to the nsbu switch if you do the 0411 swap.
  1. Vortec camshaft retard offset
    By Dave_62 in forum Vortec V6/V8 Specific
    Last Post: March 26th, 2014, 03:17 AM
  2. V2 black box computer cannot recognize black box?
    By ecc_33 in forum FlashScan V2
    Last Post: June 16th, 2011, 10:12 PM
  3. Camshaft Position Retard.
    By ZR2_350 in forum FlashScan V2
    Last Post: November 21st, 2010, 12:10 PM
