Results 1 to 10 of 13
Thread: Help with ZT-2 Wide Band
    Jul 2019
    Default Help with ZT-2 Wide Band
    Hey There
    New to EFIlive tuning. My current setup includes a ZT-2 wide band that only has an analog non linear wide band output. My ZT-2 predates the linear ZT-2(rev11).
    Can this signal be mapped in either scan V7.5 or V8?
    And How?
    Thanks so much
    D
    Jul 2019
    Let me try something else. Here is the chart can some one help with how to transpose this table in to a PID?
    Voltage 0.15 0.31 0.46 0.62 0.78 0.93 1.09 1.24 1.4 1.56 1.71 1.87 2.02 2.18
    AFR 9.7 9.9 10.1 10.3 10.5 10.7 11.0 11.4 11.7 12.1 12.4 12.8 13.2 13.7
    Voltage 2.34 2.5 2.65 2.80 2.96 3 3.12 3.27
    AFR 14.2 14.7 15.6 16.9 18.5 18.8 19.9 21.2
    Thanks dave
    I'll see if an existing calc pid maps this already, otherwise I'll make you a new one.
    Jul 2019
    Thumbs up thanks
    Look forward to seeing it
    D
    This is your calc_pids.txt edited a little, see attached...
    ( lambda is already defined, so I used this and deleted LAMBDA; wideband lambda calculation should be done earlier than the BEN pid, so it should have a lower CLC number)
    I kept the lambda expression "{EXT.AD1}*0.136+0.68" even tho it does not match the volt:afr data you posted above.
    The ZT-2 pdf says AFR= 2*V + 9.6 which with stoich 14.7 AFR (from their pdf) gives lambda = 0.136*V + 0.653 which is close to what you had.
    Aug 2013
    Hi Joe,
    Can I point out that trona specified "non linear wide band output" in the original post.
    Jul 2019
    Quote Originally Posted by statesman View Post
    Hi Joe,
    I was wondering that myself and in that case would you need to map all the voltages instead of a formula?
    Dave
    Jul 2019
    Default Thanks still figuing this out
    Thanks for the file.
    I am new to obd11 scanning and I am still struggling how to identify the WB in the list of PID's
    I keep you posted when I figure it out
    dave
    Jul 2019
    Just Following up on ZT-2 PID
    I was successful with enabling the WB using a serial WB connection to the V2. The hardware in my case was ZT2 WB controller, Opto Insulator - (protect the V2), gender changer, null modem, and V2 serial cable.
    Thanks Joecar for the modified calc-pids file now were on to VE tuning
    Hi Joe,
    Oh, I failed to notice that, thanks.
  1. I need help with my wide band
    By isak81 in forum External A/D inputs
    Last Post: January 8th, 2012, 02:46 PM
  2. Wide band
    By Harrismarine in forum FlashScan V2
    Last Post: July 6th, 2008, 11:27 AM
  3. The Wide Band....how do we really know...
    By Redline Motorsports in forum General
    Last Post: January 8th, 2007, 05:51 AM
  4. wide band o2
    By woody69 in forum Custom Operating Systems
    Last Post: October 23rd, 2006, 03:19 PM
  5. lm-1 wide band
    By 69camaro5speed in forum General (Petrol, Gas, Ethanol)
    Last Post: January 6th, 2006, 07:39 AM
