Results 1 to 7 of 7
Thread: E35 Mode-22 PIDs
    Nov 2005
    Default E35 Mode-22 PIDs
    Does the LBZ/LMM ECM not support mode-22 PID request? Or am I just being stupid and doing something wrong.
    If I send it a mode-22 PID request for a known valid PID (say, fuel rail pressure ($0023), 7E0-03-22-00-23)....and it just sends back a negative response (service not supported).
    12.9s @ 108 mph
    many thanks to Ross and Paul
    Dec 2012
    I know that some ecms get pissy with out trailing zeros for some things, ie they expect certain data lengths of 7 or 8 bytes..... but i would assume mode 22 works? I was under the impression that EDGE use mode 22 exclusively. Atleast for everything that I have ever messed with they have.
    Josh
    '04 GMC LLY
    Nov 2005
    yeah I already tried padding with 00's. Still gives a negative response, mode not supported.
    Edge uses DPIDs (mode $2C) on GM's, at least on the [GM] CAN controllers. Ive never checked on the GM J1850 controllers.
    12.9s @ 108 mph
    Oct 2010
    Dynamic PIDs is all I've ever used with E35. Kinda a pain to setup correctly, but flawless once ya get em stacked.
    PS. Many PIDs different between LBZ to LMM..
    Sent from my SAMSUNG-SM-G890A using Tapatalk
    Is it definitely Mode not supported? Or Parameter not supported?
    Off the top of my head I can't remember on these if they support Mode $22, however GM tends to stick with Mode $2C as was posted above.
    Your message format does seem valid though, it should only be a 16 bit Identifier therefore it would seem silly to have to pad with 00's to get the byte count up to a full frame.
    Also with Mode $22 they tend to have pre-defined data streams (much like how the Dodge / Cummins ECM is).
    So sending a Mode $22,$0A,$00 (just made that up) might actually result in the ECM sending back data for 4 or 5 different things in the response.
    Nov 2005
    Ross- sorry I missed this response!
    Its definitely a "service not supported" negative response. Maybe GM simply just chose to not support it on the LBZ/LMM because all of their scan tools always just use mode $2C DPID groups anyways... it works on the LML though, and im 98% sure it works on the L5P too.
    12.9s @ 108 mph
    With Bosch who knows, it's not GM's code so I guess they didn't have full control over it.
  1. Replies: 1
    Last Post: January 29th, 2015, 11:14 AM
  2. E35 Regulator PID's
    By vortecfcar in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 9th, 2011, 04:53 PM
  3. E35 injector flow rates
    By vectorbundle in forum FlashScan V2
    Last Post: February 20th, 2011, 10:41 AM
  4. E35 IAT & IAT2 PIDs.
    By Cougar281 in forum Diesel
    Last Post: August 9th, 2010, 01:11 PM
  5. Can Valet mode be used to turn SD mode off and on?
    By ForcedC5 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 17th, 2005, 11:53 AM
