Results 1 to 2 of 2
Thread: Running out of fuel
    Jul 2019
    Default Running out of fuel
    I have an 07.5 lmm that has a duel fueler kit, 15% over injectors, water methanol injection, fass lift pump, larger tank pick up tube, self ported fuel rail fitting(7/64 hole), shimmed pop off valve, and over 200,000 miles on it now. Order it the way I wanted it, now I'm really loving it!
    I have had the banks big boss kit on it after I hit 60,000 miles. Then ended up buying EFI live. Now I stack the 2 just to keep the safety's for the transmission since it's stock. The truck has been great except since I installed the injectors(fuel pump went out), my fuel rail runs up to about 24,000 psi on a wot run. It never reached the 26,000 desired pressure. I see my frp command climb all the way up, or down in percentage. My first thought was the rail running out of fuel, so I ported the fuel fitting on the driver side. I am still having this issue. I tried going back to stock torque numbers, and still have the issue. It does seem to run a little longer now before the change fuel filter come on, but it still happens. I make all my test runs without the banks on, I can't log any data with it in the system.
    I'm not sure how I can be running out of fuel with 2 pumps and 15% over injectors. My fuel rail command goes from 48% down to 12%. Also I don't think it's the pop off, as it doesn't drop instantly and it's not shooting too high. It's a gradual increase up to about 14-18,000 psi and then never catches the desired pressure. It's just 1-2000 psi under. Am I missing something? I'm not sure where to go from here. Any help would be greatly appreciated!!!
    Jul 2019
    All the tuners go to another forum?
  1. Duramax running out of fuel
    By Only350 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 25th, 2019, 03:53 AM
  2. PID's, DSP5, Turbo Vane, Fuel level, Fuel Rail, ect
    By larski156 in forum General (Diesel)
    Last Post: August 31st, 2017, 12:53 PM
  3. Replies: 1
    Last Post: September 22nd, 2010, 02:40 AM
  4. E38 Crank Fuel to Run Fuel Transition
    By Wazzup13 in forum E37, E38 & E67 PFI ECM's
    Last Post: August 1st, 2009, 10:12 AM
  5. Effects on running fuel pressure at 43.5psi....
    Last Post: April 4th, 2008, 12:57 PM
