Thread: How to graph 2 pids with equal scaling in V8
    Jan 2011
    Default How to graph 2 pids with equal scaling in V8
    In V8, I have a log file with 2 pids that I need to plot on one graph so that I can visually compare them. To do so, I need to have each pid with the same scale, the same Y(min), and the same Y(max). Initially, the pids have to be entered one-by-one, and V8 sets the initial scaling (and it's different for each pid). I can then change the scale for each pid, but I can't get the scales to both be the same. Nor can I change any Y(min) or Y(max) values independently. Is there a way that I can get the pids to overlay on the same chart? Thanks.
    If you right click on the chart you should be able to edit the min/max for each PID, is this what you are already trying?
    Jan 2011
    Got it! The first time I went there, the boxes were grayed out, and I moved on. This time, I selected the pid on the chart, and the boxes magically came alive!! Bless you!
    When editing the chart properties, you need to left-click on the part of the chart that you want to change - then the appropriate edit boxes get enabled. You can see which part of the chart you are editing because it will have a white dashed line around it.
    You can select more than one item to change at a time - by holding down the Ctrl key and left clicking in each item that you want to change. I.e. if you wanted to change all the orange charts to some other color, then click in each of the 4 orange charts while holding down the Ctrl key - they will each get a white dash border indicating that you can change them all at the same time.
    A quick (but temporary) way to copy the scales: hold down the Ctrl key and left click and drag one scale to the other scale - that will copy the scale from one to the other. That is only a temporary change, if you left-click in the second scale it will revert back to it's original scaling.
    You can also manually adjust the scaling by holding the Ctrl key and using the mouse scroll wheel while hovering over the axis. Again the change is only temporary and can be reverted by left-clicking in the axis.
    You can also manually adjust the height by using just the mouse scroll wheel while hovering over the axis. Again the change is only temporary and can be reverted by left-clicking in the axis.
    To make permanent changes, you have to edit the char properties as normal.
    Jan 2011
    Thanks!!
    Good to know, thanks.
  1. are all E92's created equal ?
    By staytuned in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: January 13th, 2019, 12:36 PM
  2. Replies: 3
    Last Post: February 29th, 2012, 07:58 AM
  3. graph very slow when im do pass through loging
    By restless@westnet.com.au in forum Black Box Logging
    Last Post: April 29th, 2011, 03:01 PM
  4. Logged info... Graph?
    By spoolinsteve in forum General
    Last Post: April 21st, 2010, 06:53 PM
  5. 50 Dry Shot Graph
    By Beer99C5 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: October 22nd, 2006, 02:20 PM
