Originally Posted by
Blacky
A quick (but temporary) way to copy the scales: hold down the Ctrl key and left click and drag one scale to the other scale - that will copy the scale from one to the other. That is only a temporary change, if you left-click in the second scale it will revert back to it's original scaling.
You can also manually adjust the scaling by holding the Ctrl key and using the mouse scroll wheel while hovering over the axis. Again the change is only temporary and can be reverted by left-clicking in the axis.
You can also manually adjust the height by using just the mouse scroll wheel while hovering over the axis. Again the change is only temporary and can be reverted by left-clicking in the axis.
To make permanent changes, you have to edit the char properties as normal.
