Results 1 to 10 of 12
Thread: Cummins CM2150
    Jul 2019
    Default Cummins CM2150
    Is there options to disable dtcs like the dodge cm2100s for the cm2150 because I am planning to replace a cm850 with the cm2150 and run it as a standalone in an offroad application. It is an ISB 6.7 running with a cm850 for now. The issue with using CM849 or 2100 is because it runs on the 250k can speed and the dodge ones would be 500k I guess. Any help or reply would be highly appreciated.
    No there isn't sorry, years ago EFILive stopped adding the ability to do this for various reasons.
    Do you need it to be 250K CAN for other modules on the vehicle?
    Jul 2019
    The dash should be 250k as well because it shows ecu data as well. And its a 24volt application. It runs a pdm. I will be having a chat with the lads who did it. Usually pdms are programmable so maybe we can alter the can rate and 12 volt output if we use the dodge ecu. I guess the cm2100 doesn't run on 24volt config.
    The Dodge ECM's do have a 250K J1939 bus as well but I am not sure what data it spits out, it might not be enough for the dash.
    I am pretty sure none of the Dodge ECM's would run on 24V.
    If you know your way around a Hex Editor etc then we are always happy to convert any HD .ctz file read with EFILive to an unencrypted .bin file.
    Jul 2019
    Actually all of this hassle is because I read a cm850 with the flashscan hd i bought recently and it was a ctz file and I couldn't edit it. I tried to source out an original bin but as it didn't have a calibration number I failed regardless of spending another fortune for the tools to try and read it. The dash uses rpm, speed and water temperature. We only work with hex editing as we do german cars so it'll be easier for us with the converted bin either the 850 or if we go 2150 route. We can turn things off on the bin with hex and then use efilive to edit the tune itself when we end up with the 2150 route because maybe we will convert it to a vgt. Please let me know where to send the ctz for the conversion. Thank you
    Just Email it to support@efilive.com and it'll come back as a bin (send the 850 file as well if you want).
    Jul 2019
    Thank you. Just sent the 850 readout. I asked before but I was turned down I don't know why.
    Yeah I don't either, more than happy to do it.
    Jul 2019
    Lately my emails end up in spam folder for people. If you are checking those emails it would be from awalution@gmail.com. does it take a long time to get the file back?
    I don't monitor that Email address, I will ask for you though.
    Edit: Got the file, will send it over shortly.
  1. Cm2150 isl epa07
    By Stevec in forum Cummins HD
    Last Post: March 12th, 2019, 11:49 AM
  2. Support for Cummins CM2150 controller?
    By Bamfm7 in forum Cummins HD
    Last Post: August 30th, 2018, 11:45 AM
  3. New to cummins - Where can I get stock cummins files?
    By GabrielMga in forum Cummins 6.7L
    Last Post: July 7th, 2016, 11:20 PM
  4. New 5.0L cummins
    By LORDDiESEL in forum General (Diesel)
    Last Post: August 21st, 2013, 09:57 AM
  5. Have the v2 for gm how to get for cummins?
    By kregelsmax in forum Purchase and Shipping
    Last Post: December 26th, 2011, 04:04 PM
