Results 1 to 2 of 2
Thread: Efi autocal file now found
    Aug 2019
    Default Efi autocal file now found
    Trying to drag over new tune files ,They show up on the autocal ,Just when i hit switch Tunes i get the error code config required
    Nov 2005
    In addition to moving the tune file to your device, you also need to program the configuration files to support the controller. You will find the steps to follow documented here https://support.efilive.com/kb_artic...6659-YAHB-3781
    Cindy
  1. merge file not found
    By Dmax_87 in forum FlashScan V2
    Last Post: July 7th, 2016, 12:51 PM
  2. BBX issue ERROR $0185 file or folder not found
    By frankenstien in forum FlashScan V2 BB Logging
    Last Post: June 1st, 2015, 07:53 PM
  3. Can't BBX full flash (Error $0502, script file not found)
    By spandit in forum FlashScan V2 BB Logging
    Last Post: April 14th, 2011, 09:34 AM
  4. Error $0502 Script file not found
    By jcow in forum Allison 5 & 6 Speed
    Last Post: April 14th, 2011, 01:53 AM
  5. New to EFI, but found some interesting PIDS
    By serpa4 in forum General (Diesel)
    Last Post: March 19th, 2007, 02:42 PM
