Thread: Bidirectional controls
    May 2019
    Default Bidirectional controls
    Hello,
    I am working with a 2008 GMC Yukon XL Denali, 6.2L.
    The GM service manual says that a scanner can be used to activate the vehicle's fuel pump. I was hoping to be able to do this with my EFI Live FlashScan v2. Looking in the EFILive V75 Scan manual, it would appear that bidirectional controls are only available on LS1 and LS6 engines. Is this true? How risky would it be to attempt activating the fuel pump even though this isn't an LS1 or LS6?
    Thank you for any help.
Name:	bidirectional controls LS1 LS6 fuel pump.png
    May 2010
    Yes just in LS1B we can activate it but not in E38,E67
    EFILive Tuner
    Connect to the ECM and open up the DVT tab to see if it's an option. That doc is super outdated.
    May 2019
    Thanks for your help, guys.
    +1 user manual is outdated.
    When you connect to vehicle, on DVT tab you will see a drop down menu titled "Target Controller", select E38
    then on the Output tab you will see Fuel Pump Duty Cycle.
    May 2019
    Much appreciated, thank you Joe.
  1. E78 BiDirectional Controls DVT
    By rcmn0022 in forum E78, E83, E84 PFI ECM's
    Last Post: May 5th, 2014, 10:04 AM
  2. E78 BiDirectional Controls DVT
    By rcmn0022 in forum E39, E80, E82 & E92 SIDI ECM's
  3. Bidirectional controls and spark....
    By Redline Motorsports in forum General
    Last Post: June 12th, 2006, 02:35 PM
  4. Bidirectional Controls and V7
    By bink in forum General (Petrol, Gas, Ethanol)
    Last Post: October 8th, 2005, 04:53 PM
