Results 1 to 2 of 2
Thread: questions on clear trans adapts / relearn process
    May 2019
    Default questions on clear trans adapts / relearn process
    Hello,
    I am working with a 2008 GMC Yukon XL, 6.2L, 6L80 transmission (T43 TCM), using the version 7.5 scan software with a Flashscan V2. Very new to EFI Live, as you'll see.
    I read this post from Longslyde about how to go through the clear (reset) trans adapts process and the fast relearn process. Very helpful, thank you.
    Am I supposed to have the engine running for the entire process (both resets and fast relearn)? Or just for the fast relearn?
    It is mentioned that Clutch Purge must be enabled for fast relearn to take place. I didn't find Clutch Purge in the DVT tab (see screen capture). Is Clutch Purge located somewhere other than the DVT tab?
    I quickly learned that the version 8.0 scan software doesn't have the DVT tab so that means use version 7.5 (in case someone else comes across this problem).
    Thank you for any help.
Name:	clutch purge_T43_DVT.PNG
    To clear the Trans Adapts, you should be able to do it with key on engine off.
    Hmmm, not sure about Clutch Purge.
  1. Trans Relearn
    By Pballistic in forum Diesel
    Last Post: March 13th, 2016, 06:35 AM
  2. How do i do a Trans reflash/relearn on my LBZ
    By Haydens_Revenge in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 19th, 2014, 12:48 PM
  3. Cruze questions (1.4 trans and 1.8 tune)
    By Boost in forum E78, E83, E84 PFI ECM's
    Last Post: August 17th, 2011, 04:21 AM
  4. Clear P0401 with Blocker Plate and tire size questions.
    By SSTuner in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 31st, 2010, 04:59 AM
  5. trans relearn???
    By newguy2diesel in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 2nd, 2008, 06:31 PM
