Thread: 2013 cab and chassis dual fuel tank table
    Default 2013 cab and chassis dual fuel tank table
    I am having trouble with fuel pushing out the filler neck of the front tank running down the road. It did not start happening until I deleted with a H&S tuner. I have downloaded several stock files with the matching segment numbers, however none of them have any provisions or tables for the dual tanks. Is there options in the LML file for dual tanks?
    Dec 2005
    H&S has what it has available, if you need a stock file with dual tanks we have them available for purchase on our web site.
    They are a .CTZ File and can be edited, however that format from EFI-Live is not compatible with any other tuning software.
    www.mscservices.net
    Do all segment numbers have to match? I feel like the main operating system and the fuel system segments should cover what I need, but yet they dont show the dual tank parameters.
    Mar 2009
    I have 2 cab & chassis tune files, but neither one has the fuel system segment's mapped out. The H&S probably doesn't have a dual tank fuel system segment in it which would cause your issue because the ECM handles the transfer pump operation.
    Mar 2009
    Quote Originally Posted by CoersDiesel View Post
    For LML EVERY segment MUST match perfectly or else you WILL have problems.
    I pulled stock tune files off of the forum from you(THEFERMANATOR). Thats where I found that there are no provisions in them for the dual tanks, which I found odd since most, if not all, cab and chassis have dual tanks. Another tuner stated that he had tuned over a dozen cab and chassis trucks with a H&S tune without problems. I found that the data shows the fuel level only getting to 92% with both sending units all the way up. The transfer pump will work when the tanks get below full and only pushes out after a fill up.
  1. Replies: 1
    Last Post: May 20th, 2018, 02:01 PM
  2. 08 Cab and Chassis
    By Dom_c13b in forum Cummins 6.7L
    Last Post: October 24th, 2016, 05:37 AM
  3. Cab and Chassis help- Please!
    By LBZoom in forum Cummins 6.7L
    Last Post: July 16th, 2014, 06:18 AM
  4. 2013 cab chassis tune
    By hardknocks in forum Duramax 2011+ LML / LGH
    Last Post: March 3rd, 2014, 12:53 PM
