Results 1 to 4 of 4
Thread: Post tune stability control issue VE L96 6l80e
    Aug 2019
    Default Post tune stability control issue VE L96 6l80e
    Hi all iv just done my first ve e38 tune it's a 2008 ve as wagon OS 1624402 everything is perfect or so I thought but now the stability control keeps turning its self on and off does anyone have any idea what this may be iv asked a friend who tunes alot of conversions but no ve comoodores and he is clueless aswell I'm in the same boat any help would be greatly appreciated
    Aug 2019
    Also meant l98 sorry and not sure how to change this
    Aug 2019
    Anyone? Any idea at all?
    Sep 2019
    The VE stability control issue could be one of two things.
    1. The rear wheel ABS sensors are faulty or on the way to failure. However if this is an issue it should throw the wheel sensor code. Not sure if EFIlive autocal of Flash scan 2 will show a log code for this, you may need a scan tool like snapon or Ourauto.
    2. On the rear drivers side there is also a plug in short wiring loom that controls both rear wheel sensors, this wiring loom plugs in just in front of the rear suspension beam. The plug forces the wiring to basically fold back on it self. It will appear as if the wring is all good but it becomes quite brittle and will cause the fault. I would check both this short wiring loom section and the wheel sensors, they are not expensive to replace and are a common issue that will will light the stability light.
    That said I have just recently had had the crank sensor fail also, it will also throw the stability light as fault also.
  1. swapping Camaro 6l80e to Vette 6l80e
    By secrt007agt in forum General
    Last Post: January 31st, 2016, 04:43 AM
  2. Service Stability Control ??
    By Boost in forum E37, E38 & E67 PFI ECM's
    Last Post: March 26th, 2008, 12:31 AM
  3. Getting my KR under control going well, one other issue
    By Whippled 496 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 12th, 2006, 04:18 PM
  4. Custom O/S to control a 6L80E Trans?
    By vetteboy2k in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 2nd, 2005, 02:08 PM
