Results 1 to 7 of 7
Thread: DTC report from V8 Log file?
    Jun 2011
    Default DTC report from V8 Log file?
    Can someone tell me how to get the dtc report from a saved v8 log file? Stupid me flashed the truck before I read out the dtc but I do have it setup to save dtc upon saving a log file. I exported the log to a .CSV file but the data is kind of scrambled.. I do know their are some dtc. It just showed up kinda scrambled like the picture below. What should I be opening the .CSV file with? Am I on the right path. Will attach log too.
    Sent from my moto z3 using Tapatalk
    Jun 2011
    Jun 2011
    Ok. I found the correct format to view the data. I do not see any dtc though.
    Jun 2011
    Anybody. Is this possible?
    There are no DTCs stored in that log file. Even if there were, when you export logged dat to a *.csv file only the PID data is exported, not all the other meta data such as DTCs.
    To view DTCs saved in a *.pld logged data file, use the drop down arrow on the [Config] button at the bottom of the scan tool window and select the option "Display/Change Log File Information", then select the [DTCs] tab page. (Or use the hotkey Ctrl+I)
    Jun 2011
    That's weird their are none. This is a competition truck that has several random dtc as I do not have them shut off in the tune I don't think. I'll double check they are reporting correctly tomorrow with another saved log.. This engine is standalone setup that only only uses a a few sensors.
    Jun 2011
    Dtc are reporting correctly. Thanks for your help Paul
  1. Engine DTC Processing Differences in Tune File
    By CR500 in forum Petrol / Gas
    Last Post: March 9th, 2019, 11:47 AM
  2. Log file help.
    By aaronr in forum Gen IV V8 Specific
    Last Post: September 21st, 2010, 03:27 AM
  3. No DTC's in log file
    By spandit in forum Black Box Logging
    Last Post: September 16th, 2010, 03:51 AM
  4. Excel DTC File from Husker Diesel....
    By husker_diesel in forum General (Diesel)
    Last Post: June 16th, 2009, 03:31 AM
  5. Would someone be willing to look at a log file?
    By stigmundfreud in forum Gen III V8 Specific
    Last Post: May 6th, 2007, 09:47 AM
