Results 11 to 20 of 30
Thread: September 2019, Beta Release - Update 2
    Sep 2015
    If you are still getting the "SGM Detected" message then you need to recheck the instructions for your bypass wiring.
    Thank you for the reply—
    I tried connecting the bypass wire into all the different slots and none of them seem to provide power. However, I put the factory wires back into the obd2 port and it powers the port.
    Can anyone verify how many volts the bypass switch provides to the obd2 port?
    Quote Originally Posted by honduh View Post
    I think you REALLY need to contact the company that makes the bypass kit for guidance, the OBD-II port needs 12V.
    Sep 2015
    Will do! Thank you.
    Jul 2003
    V8 is not copying the flash scripts onto the autocals. No matter what I do always returns Error $0502
    Dec 2012
    Hey Paul,
    Here's a funny bug.
    Lets say you are building a CAX. If you use windows calculator in programmer mode (windows 10), type in an address, (using just your keyboard) hit '+' and add your offset hit 'Enter' then 'Ctrl+C' and then paste that address into your CAX.
    When you go to load the CAX into 7.5... It errors out saying that the 'PCM is unrecognizable and to send the file in. Backspace that address and retype the same exact address in by hand and boom... works perfectly fine. lol
    Josh
    '04 GMC LLY
    It's a known bug (I mean feature) in the Windows calculator. The calculator tries to be "smart" and add the Unicode characters:
    E280AC Pop directional formatting
    E280AD Left-to-right override
    So it ends up looking like this in the cax file:
    Not sure what Microsoft was thinking when they chose to make that brain-dead decision.
    Lots of complaints online... Google for: windows calculator clipboard error
    Dec 2012
    Lol you just beat me to the punchline. I was just writing about that. Gotta love windows programmers lol that definitely got annoying quick
    Josh
    '04 GMC LLY
    That Windows 10 calculator is a major step backwards, I use (daily) a port of the old Windows 7 calculator and never run in to those issues.
    https://winaero.com/blog/classic-cal...s-10-creators/
  9. #19
    lol, Microsoft, lol
  10. #20
    Dec 2012
    Paul, another bug...
    When Caxing 1D table that is 8 bit, if its a single ROW, it decides to skip bytes for fun. lol
    Here is where it gets odd, define the 2nd row and now you can see the skipped bytes in the 2nd row
    Do it as columns and you're fine. No skipped bytes, lol
    Josh
    '04 GMC LLY
  1. I would like to beta test for the 2019 Ram 2500 6.7L Cummins.
    By CumminsTwang in forum Do you want to be a Beta Tester?
    Last Post: August 5th, 2019, 01:47 AM
  2. May 2019, Beta Release (Updated May 30, 2019)
    Last Post: May 28th, 2019, 04:43 PM
  3. Current Public Release (Updated - Feb 2019)
    Last Post: April 17th, 2019, 06:34 AM
  4. August 2018, Beta Update #4
    Last Post: August 28th, 2018, 11:01 AM
  5. August 2018, Beta Update #3
    Last Post: August 4th, 2018, 04:29 PM
