Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: September 2019, Beta Release - Update 2
  1. #21
    Dec 2012
    That Windows 10 calculator is a major step backwards, I use (daily) a port of the old Windows 7 calculator and never run in to those issues.
    https://winaero.com/blog/classic-cal...s-10-creators/
    Thats much better!
    Thanks!
    Josh
    '04 GMC LLY
  2. #22
    Paul, another bug...
    When Caxing 1D table that is 8 bit, if its a single ROW, it decides to skip bytes for fun. lol
    Here is where it gets odd, define the 2nd row and now you can see the skipped bytes in the 2nd row
    Do it as columns and you're fine. No skipped bytes, lol
    Some (many) controller types are defined with a byte-alignment of 2 bytes. That means if a calibration is defined with a data size of 8 bits or less and with an odd number of rows, then the last byte of each column is skipped. That ensures that each column starts on a word boundary.
    You can't change that byte alignment with a setting in the cax file - it's hard coded into the software.
    In the new V8 editor it is user define-able.
    Also in V8, you can simply transpose the table so that rows become columns and columns become rows which makes it easy to view/edit/copy/paste the data in the same format as "other software"
  3. #23
    Apr 2011
    I just uninstalled the current public software and downloaded/installed this beta release. I get this error message when attempting to open any of the 2019-2020 6.7L files from the Mega.nz file link. Any ideas?
    Thanks,
    Mike
    2019 Ram 6.7L 68RFE
    2003 VW Jetta TDI
  4. #24
    Mike, the issue is that V7 & V8 have not been updated to load those OS's in any public release.
    You can try to extract the attached rar into the Calibrations folder for V7 and the dat file for V8 and then see if your files load up.
    CMF_Calz.rar extract to:
    C:\Program Files (x86)\EFILive\V7.5\Calibrations\CMF
    CMF.dat save to:
    C:\Program Files (x86)\EFILive\V8\Controllers\Identify
  5. #25
    Senior Member 2006Cummins's Avatar
    Sep 2011
    Thanks for the reply Ross. I guess I am a little confused. I see in the release notes that this beta software that I installed supports CMF. I checked to be sure that the CMF .inx and .dat files were installed. I will try uninstalling and reinstalling the software.
    Mike
    2019 Ram 6.7L 68RFE
    2003 VW Jetta TDI
  6. #26
    It is beta software but it was released in September 2019, the .ctz files you are possibly trying to use came out after that beta was released. The couple of files I posted above contain the updates to support 19/20 files that came out after the beta.
  7. #27
    Dec 2012
    Any Idea why when I bring in a bone stock IA80012.04 file into V7.5.... I get an incorrect checksum? Even converted from XCAL using yalls tool... same problem... V8 too using the files from above.
    Josh
    '04 GMC LLY
  8. #28
    Sorry I'm not sure Josh, the IA80012.04 file I have loads up just fine. I've just sent a PM.
  9. #29
    Dec 2012
    Thanks! Investigating.
    Josh
    '04 GMC LLY
  10. #30
    Probably should mention that they are up to IA80012.07 now (released mid April), your file was released Nov 2019 (no clue what they've been changing).
  1. I would like to beta test for the 2019 Ram 2500 6.7L Cummins.
    By CumminsTwang in forum Do you want to be a Beta Tester?
    Last Post: August 5th, 2019, 01:47 AM
  2. May 2019, Beta Release (Updated May 30, 2019)
    Last Post: May 28th, 2019, 04:43 PM
  3. Current Public Release (Updated - Feb 2019)
    Last Post: April 17th, 2019, 06:34 AM
  4. August 2018, Beta Update #4
    Last Post: August 28th, 2018, 11:01 AM
  5. August 2018, Beta Update #3
    Last Post: August 4th, 2018, 04:29 PM
