Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: September 2019, Beta Release - Update 2
    Default September 2019, Beta Release - Update 2
    We strongly recommend that you do not install the beta software over the top of your production systems. It is possible that the beta test software may fail and your production system may not be recoverable. lf you conduct a tuning business, please take the necessary precautions to protect your business. EFILive recommends beta testers use a separate FlashScan V2 device (when installing the latest beta firmware) and only install the EFILive beta test software on a separate PC, laptop or virtual machine.
    Release Notes:
    Version Numbers:
    After installing this beta release you should have the following software, boot block, firmware versions installed:
    • EFILive V7 software: V7.5.29 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.2.25 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • Boot Block: V2.07.008 (Jul 4, 2018) To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
    • Firmware: V2.07.141 (Sep 19, 2019) To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
    Download here:
    Known Issues:
    Issue #1:
    Workaround:
    None.
    Issue #2:
    Workaround:
    Dec 2012
    Paul,
    Has the 32 bit limit on PKT PIDs been lifted yet?
    I also might have a problem with E98 DMA pids as welll.
    Example.
    If requesting address 0x400134E8, when its verifying the PIDS, it seems to only be requesting 0x40000000. It doesent send the rest of the address.
    I will 100% verify this later this afternoon with some logs for you as I forgot to save when I tested yesterday, unless you beat me to it. lol
    If you would like me to send you a copy of my Custom List, Id be more than glad to PM it to you.
    One more... It seems that when I use a CAX with 32bit FLT and use the 'Inv' function. (Its for the EQ AFR table on cummins) it breaks everything and just displays 0's... but set that back to zero and it displays again. Factor is set to '1'. I can send you an example of this as well if you'd like.
    Thanks!
    Josh
    '04 GMC LLY
    Paul,
    Not in this release. Working on it for the next major release of V8.
    Example.
    Thanks!
    I'll take a look into both of those issues.
    Thanks!
    The problem is:
    When a calibration definition is loaded the software figures out the hard min and hard max values based on the bit size, the factor, the offset and the inverse settings. That makes sense for SNM and UNM type calibrations that have fixed raw/hex ranges but it makes no sense for FLT type calibrations.
    Unfortunately, the "auto-generate hard min and hard max values" routine is being called when the data type is FLT and inverse (it should not be called - it should just use the values supplied by the cax file) . That causes the hard min to be set to 1E-35 and the hard max to be set to -1E-35. Those values are wrong and the min is actually greater than the max. That is what is causing the calibration to display zeros. I cannot see any workaround to the problem so a fix will be in the next beta update (which is due out this week sometime).
    Still working on the user defined DMA PID address issue...
    Dec 2012
    The problem is:
    Ahhh.... That makes sense! haha. Well thanks for figuring it out!
    If there is anything you need from me for the DMA issue, let me know.
    Thanks again Paul!
    Josh
    '04 GMC LLY
    Example.
    If the controller's operating system against which you are verifying the DMA PID(s) is not defined for the DMA PID, then it will try to verify with the address $40000000 - and obviously fail and mark the PID as unverified.
    So make sure that the OS in the controller is the same* OS listed in the [Dma_OS] section and that it matches the same "column" as the DMA PID's address in the [Dma_Addr] section.
    *Same means the same GM stock OS, so if you have a custom OS in the ECM then you should use the matching GM stock OS in the *.ini definition file.
    Thanks!
    That should be fixed with the latest beta-2 update released today.
    Jul 2003
    V8 Editor V8 Editor V8 Editor V8 Editor........ I almost forgot...V8 Editor.. how can i use it????
    Sep 2015
    I am trying to license and tune a 2019 Cummins 6.7 and the bypass switch in slots 6,14 on the OBD2 port don't power the OBD2 port. With the factory wires in slots 6, 14 i receive the error code $0333: Security Access Denied ($33). How should I proceed? I am using version V8.2.25 with Firmware 2.07.141
    If you are still getting the "SGM Detected" message then you need to recheck the instructions for your bypass wiring.
  1. I would like to beta test for the 2019 Ram 2500 6.7L Cummins.
    By CumminsTwang in forum Do you want to be a Beta Tester?
    Last Post: August 5th, 2019, 01:47 AM
  2. May 2019, Beta Release (Updated May 30, 2019)
    Last Post: May 28th, 2019, 04:43 PM
  3. Current Public Release (Updated - Feb 2019)
    Last Post: April 17th, 2019, 06:34 AM
  4. August 2018, Beta Update #4
    Last Post: August 28th, 2018, 11:01 AM
  5. August 2018, Beta Update #3
    Last Post: August 4th, 2018, 04:29 PM
