Thread: Fuel Filter Restriction
    Sep 2015
    Default Fuel Filter Restriction
    I am tuning a 2015.5 and starting to make some power. Every time I floor it the fuel filter life goes to 0% on the dash (about a 120hp tune). Is there anything that can be done to make it less sensitive? I can unplug the sensor but would rather not have to do that on every truck. Im sure someone has ran into this before.
    Your draining the rail, watch your logs, either pull some full out of it or get a lift pump.
    04 LB7
    2010 LMM
    2015 LML
    Sep 2015
    Why am I not getting a P0087 if this is coming from low fuel pressure?
    My LML doesn't either, drains the rail then fuel filter life goes to 0%. It's not the same as the older trucks.
    04 LB7
    2010 LMM
    2015 LML
    Sep 2015
    Yes that’s what this one is doing. Thanks!
    New Member FC5452's Avatar
    Jan 2016
    Shut the fuel minder switch off. The only thing that will set a code is the 0087 as you know,
    It does not take much to trip that stupid switch, add a lift pump as stated.
  1. Fuel Filter Minder countdown strangeness
    By Cougar281 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 4th, 2010, 01:36 PM
  2. Fuel Filter
    By Shaftner87 in forum Duramax LLY
    Last Post: May 9th, 2010, 01:01 AM
  3. found restriction to be my air filter
    By Aint Skeered in forum General (Petrol, Gas, Ethanol)
    Last Post: March 5th, 2009, 02:30 AM
  4. Injectors or fuel filter?
    By Ritch in forum Gen III V8 Specific
    Last Post: April 20th, 2008, 12:09 PM
