Results 1 to 5 of 5
Thread: safe mode on 5.7
    Sep 2019
    Default safe mode on 5.7
    Can any one point into a direction that solve a safe mode issue on 2004 Monaro CV8 vehicle. The vehicle will randomly go into safe mode and we haven't been able to find the cause codeP2125 logs but I don't believe he throttle peddle is the issue.
    try a different Thottle Postion Sensor
    330 rwkw EFILIVE OS 01290005 SD Cam / Head Tuned 6 speed VY SS Commodore
    10/71 Blown 572 Big Block Chev HQ 2 Door Monaro
    GM Performance Centre
    Busselton WA
    AUSTRALIA
    Phone: 0447 003050
    Sep 2019
    Don't have one spare to try. However I have managed to get a hold of Holden power train specialist, Holden don't have a part replacement currently on hand but the unit was manufactured in England, hoping they can help with the peddle sensor issue.
    Sep 2019
    Quote Originally Posted by gmperformancecentre View Post
ID:	23010Click image for larger version.
    I appreciate your reply, anychance that you could take a look at the photos at let know your view on the circuit board
    Can you check continuity across the solder joints.
    Look at each one thru a magnifer/lupe, see if there are any cracks in the solder joints... you may have to reflow the solder.
    The "wiped" areas of the traces: can you clean these (rub very lightly with brass wool, just clean them, do not take metal off).
  1. GEN 111 safe mode
    By Mike W in forum General
    Last Post: September 10th, 2019, 11:18 PM
  2. Hope all are safe
    By Spence in forum Lounge
    Last Post: September 4th, 2010, 02:54 PM
  3. Safe Mode?
    By Grey Silver in forum Gen III V8 Specific
    Last Post: August 27th, 2007, 05:34 PM
  4. Valet mode safe for building boost?
    By SS2win in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: December 20th, 2005, 03:19 AM
  5. Safe way to tune VE when boosted?
    By VortechC5 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 28th, 2005, 05:36 PM
