If I do that correctly that should put zeros from 68 to 92 square mm. Did I do that right?
I wish I had better explainations for the idle parameters as it would make it easier to understand what I am touching!
Even some of the idle scanning pids need further clarification.
What am I doing by moving that table down 6 spots? Also what is the explaination of "desired air flow" and why should it match the maf grams/sec? I made a map to log maf/grams/sec with coolant temp going up the left and rpm across the top from a cold start. Now that I think about it, I should of made the map coolant temps match the coolant increments in the table!
. By copying those values into the DAF table is telling the PCM what?
Also what is the DEIAC b pid??
Howard
