Results 1 to 3 of 3
Thread: HELP!! 2013 Chevy abs signal delete
    Sep 2019
    Exclamation HELP!! 2013 Chevy abs signal delete
    Ok so I am new to this forum but had a quick question on my truck. I have a 2013 Chevy 2500 that I recently put a dually axle on it. Everything went well until I realized that the 2500 chevys had rear abs sensors and the 3500 axles that year did not. Now I am obviously getting all kinds of warning lights on and it has enabled my trailer brake controller. I have been told that I could have the rear signals shut off with my efi live that have on the truck now. Is that possible?? I am not sure what else could be done. Thanks for any and all your help!
    May 2019
    have you ever figured this out?
    I had a similar issue, and my solution was to jump the wire for the front wheel speed sensor signal with the wire for the rear wheel speed sensor signal - separately for left and right ones. I did it in the harness near the EBCM. The data now shows that the rear wheel spins with the same speed as the front one. The lights went away. I have not tested in slippery conditions and not sure if this can confuse the ABS during hard braking and cause losing control - use at own risk.
    Dec 2005
    Email me the file you are working with, I might be able to help you out with that issue.
    www.mscservices.net
  1. 2013 lml delete question
    By outlaw83 in forum Duramax 2011+ LML / LGH
    Last Post: July 7th, 2016, 10:12 AM
  2. 2000 Chevy 02 Sensor Delete?
    By JordanSBC427 in forum Gen III V8 Specific
    Last Post: November 1st, 2014, 02:15 PM
  3. Tuning on a chevy 2013 3500
    By techsalvager in forum General (Petrol, Gas, Ethanol)
    Last Post: September 12th, 2014, 06:17 AM
  4. 2011-2013 Chevy Volt
    By cmturn0 in forum Do you want to be a Beta Tester?
    Last Post: January 9th, 2014, 01:17 PM
  5. ECM to ABS speed signal
    By THEFERMANATOR in forum Duramax LB7
    Last Post: June 28th, 2009, 03:23 PM
