Results 1 to 3 of 3
Thread: A50 stock base file-2012
    EFILive Reseller
    Nov 2005
    Default A50 stock base file-2012
    I have done quite a few Allison A50 replacement TCM's over the years, but I've come across what is to me an oddball in the 2012 model year.
    Typically they all seem to use OS 24266880 and Trans 24269908 but I have come across one that uses 24269909 which I do not happen to have. I've come across this same scenario with a lone 2011 truck as well, but I happened to have the file for that one. In this case I do not.
    www.kennedydiesel.com
    Specializing in Duramax Performance
    More than just a salesman-I use and test the products that I sell on a daily basis.
    Superflow Lie Detector in house
    Hi John,
    Not one we've had sent in for support either sorry.
    Might be worth checking out TIS to see what the latest update is for that TCM, might just be a case of a really old OS in there.
    EFILive Reseller
    Nov 2005
    Hi John,
    Thanks Ross
    It's an odd one but that is the current TIS listing. I sent the replacement module to the customer with the more mainstream file loaded and will see how it goes. I had him try to read the original unit using an Autocal that he had as a pass through, byt he got the $0101 so module may be bad or some other CAN issue. At any rate I requested that he send me the original unit so I can try to read it.
  1. 5500 Party Bus Stock Base File needed
    By comnrailpwr in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 27th, 2018, 07:33 AM
  2. 2010 A50 Stock File OS 24252364
    By LBZoom in forum Allison 5 & 6 Speed
    Last Post: March 26th, 2018, 08:01 AM
  3. 2012 C6 M6 Base Model - Need base file!
    By GR8GAME in forum Gen IV V8 Specific
    Last Post: April 4th, 2016, 03:44 AM
  4. 2012 dodge insearch of a stock file
    By Scarface in forum Cummins 6.7L
    Last Post: November 2nd, 2015, 03:20 AM
  5. Stock tuning file for 2012 6.7
    By dodgeram5-92500 in forum Diesel
    Last Post: January 8th, 2015, 08:50 AM
