Results 1 to 3 of 3
Thread: Trying to log pressure sending unit
    Aug 2011
    Default Trying to log pressure sending unit
    I wanna start off by saying, i have been searching for a few days now, and trying to read as much as i can.. i have some isspro ev2.. i have read the tutorial on setting it up for an ls1. But it also referees to a v1, I'm guessing that its basically the same.. however i am very unsure, when it comes to configuring the pid in efi live.. i find the pid in the tab, it shows psi, but no values. Could someone point me in the correct directions?
    If i tap into the 5v signal wire and run it to the v2 and connect it to the positive side on the orange tee, on a/d input 1 do i also need to run a ground wire to the v2 as well?
    You want to log the oil pressure sender...?
    The problem is when you tap into its signal, you may change the signal... you could try it and see... I would add an additional oil pressure sensor (probably on the oil filter housing).
    BTW: it looks like your emails to me are getting filtered out (my email provider blocks @gmail.com and @yahoo.com)... send me a test email.
    Aug 2011
    Sent
  1. Digital $30 trans PSI sending unit, works great!
    By Mr. P. in forum External A/D inputs
    Last Post: November 20th, 2012, 05:35 AM
  2. Replies: 3
    Last Post: August 23rd, 2012, 08:26 AM
  3. oil pressure sending unit
    By BRD-PREY in forum General
    Last Post: July 31st, 2011, 10:58 AM
  4. Oil Pressure Sending Unit - Recommendations?
    By Johnnydangerously in forum General (Petrol, Gas, Ethanol)
    Last Post: June 12th, 2009, 03:37 AM
  5. Line Pressure Max/Stock Unit???
    By turboolds in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 2nd, 2008, 11:53 AM
